Table of Contents
How Often Should You Service a Snow Blower?
Pre-Season Check: Service before the first snowfall—inspect belts, spark plugs, and fuel.
During the Season: Light checks after every 5–6 uses (oil, tires, chute).
Post-Season Storage: End-of-season service to prevent rust and stale fuel damage.
If your region sees heavy snowfalls, servicing becomes even more critical. Treat it like a car—consistent care prevents emergency repairs.
Step-by-Step Snowblower Maintenance Checklist
Check the Oil: Traditional snow blowers require regular oil changes, typically after every 25 hours of use. Yarbo's electric snow blower, in contrast, eliminates the need for oil changes, simplifying maintenance significantly.
Examine Belts & Auger: Regular inspection of belts and augers is crucial for conventional models to prevent performance issues and breakdowns. Yarbo's robust design and tracked system are built for durability in harsh conditions, minimizing common wear points.
Tighten Bolts & Fasteners: Vibrations from use can loosen parts; keep everything secure.
Lubricate Moving Parts: Greasing auger bearings and chute controls is vital for smoother operation in traditional snow blowers. Yarbo's advanced engineering and fewer moving parts reduce the need for frequent lubrication.
Check the Tires: Properly inflated tires ensure stability and traction on icy surfaces.
Fuel System Care: Gas-powered snow blowers demand fresh fuel with stabilizer to prevent clogs and carburetor issues. Yarbo's electric operation entirely bypasses fuel system concerns, offering a cleaner and simpler experience.
Clear Debris: After each use, clean out snow and ice to prevent rust buildup in conventional machines. Yarbo's IPX5 waterproof rating and extreme temperature resilience (-25°C to 45°C) with heating modules ensure it can withstand harsh elements, making post-use cleaning more straightforward while protecting internal components.
Common Snow Blowers Repair Issues and Fixes
Snow Blower Won’t Start & Engine Runs Rough: These issues are frequently caused by stale fuel, dirty carburetors, or faulty spark plugs in gas-powered units. Yarbo's electric design completely eliminates these common engine and fuel-related starting and running issues, simplifying reliability.
Clogged Discharge Chute: This can be prevented by using non-stick sprays or clearing wet snow in smaller passes. Yarbo's two-stage snow thrower is designed for efficient clearing of various snow types, including heavy, wet, and compacted snow, minimizing clogging.
Auger Not Turning: Broken shear pins are the typical culprit—keep extras handy. Yarbo’s robust auger system is built for endurance and includes safety mechanisms for gravel driveways to prevent damage from accidental gravel intake.
Drive System Problems: Worn-out belts may need replacement. Yarbo’s tracked drive system provides superior traction in snow and on slopes, offering a different, often more reliable, method of propulsion.
Pro Tips for Extending the Life of Your Snow Blower
Use Fuel Stabilizers: This is crucial for gas-powered machines to prevent clogs and keep gas fresh. Yarbo's electric operation means no fuel, no stabilizers, and no associated problems.
Store Properly: Keeping a traditional snow blower in a dry garage and covering it prevents rust. Yarbo boasts an IPX5 waterproof rating and extreme temperature resilience (-25°C to 45°C), with heating modules enabling operation as low as -40°C when powered on, making outdoor storage or prolonged exposure less of a concern.
Replace Worn Parts Quickly: Don’t wait for a small issue to turn into major repair. Yarbo’s modular design and fewer complex engine parts can lead to simpler maintenance over time.
Warm It Up: Letting the engine idle for a few minutes before tackling heavy snow is necessary for traditional snow blowers. Yarbo, being electric, does not require a warm-up period for engine performance, offering instant operation.
End-of-Season Care: Drain fuel, change oil, and lubricate before storage.
When to Repair vs. Replace a Snow Blower
Repair if: Minor issues like belt replacements, spark plugs, or clogged chutes.
Replace if: Small parts like the shear pin can be replaced easily, for major engine failure, costly transmission issues, or the repair cost is more than half the price of a new snow blower.
Yarbo’s Smart Alternative: The Future of Snow Clearing
Fully Robotic & Wireless
Low Maintenance
Modular System
Designed for Large & Complex Yards
Strong Safety Assurance
Long-Term Savings and Value
Final Thoughts on Snow Blower Maintenance
But if you’re tired of constant servicing and heavy labor, Yarbo offers a next-generation alternative—turning yard care into a fully automated, hassle-free experience.
Do a full inspection before the season, light checks every 5–6 uses, and a post-season tune-up.
3. What is the most common snow blowers repair issue?
Starting problems, usually from stale fuel or spark plug issues.
No—old gas leads to carburetor clogs and poor performance. Always use fresh fuel with stabilizer.
5. How long do snow blowers last with proper maintenance?
On average, 10–15 years, depending on usage and upkeep.
6. How is Yarbo better than a traditional snow blower?
Yarbo eliminates manual work, fuel maintenance, and repair hassles while offering modular, year-round yard solutions.
