What Is a Shear Pin & When to Replace It — Snow Blower Guide
Yarbo Snow Blowers
A shear pin as the name suggests is a small, purpose-designed metal pin that connects your snow blower's auger (the rotating blades that scoop up snow) to its drive shaft, allowing the auger to spin and clear snow effectively.
Its key function is to act as a mechanical safety device: it is engineered to break cleanly if the auger encounters a hard object (like ice, rocks, or thick debris).
This controlled breakage prevents the impact force from damaging more expensive and critical parts of your snow blower, such as the gearbox, auger shaft, or engine.
In this article, you will learn in detail what is a shear pin used for, and how do shear pins break and how to replace these shear pins for different types of snow blowers.
What is a Shear Pin Used For In a Snow Blowers?
Protecting Your Auger and Gearbox
Your snow blower's auger and gearbox are critical components, and repairing or replacing them can be expensive. Shear pins act as a cost-effective safeguard against mechanical failures.
Preventing Costly Damage
Without shear pins, a sudden blockage could crack your gearbox, bend your auger, or even damage the engine, leading to high repair bills.
How Do Shear Pins Break?
Shear pins break by design to protect your snow blower from serious damage. They are engineered to snap when your snow blower’s auger hits a hard object (like rocks, ice chunks, or hidden debris) that could otherwise transfer sudden force to the gearbox or engine.
Here are the main reasons shear pins break:
  • Hitting hard objects: When the auger encounters something it can’t cut through, the shear pin breaks to stop the auger immediately, preventing damage further up the system.
  • Overloading the auger: Trying to clear heavy, packed snow too quickly can overload the auger, causing the shear pin to break to relieve stress.
  • Worn-out pins: Old or rusted shear pins can become weak over time and break under normal operation.
  • Improper installation: Pins installed incorrectly or over-tightened can be stressed unevenly and break prematurely.
Types of Shear Pins for Snow Blowers
OEM vs Universal Shear Pins
OEM shear pins are designed for your specific model, while universal pins may fit multiple models but may not provide the exact strength required.
Material and Durability Factors
Most shear pins are made of soft metal alloys to break easily when required while maintaining sufficient strength during regular use.
Signs Your Snow Blower Shear Pin Needs Replacement
Visible Breakage:
Check for missing or visibly broken pins on your auger shaft.
Auger Not Spinning:
If your auger isn't spinning while the engine runs, it may indicate a broken shear pin.
Step-by-Step Guide to Replacing a Shear Pin
Tools You Need for Shear Pin Replacement
To replace a shear pin on your snow blower, you will need a few essential tools to ensure a smooth and safe process. Keep replacement shear pins on hand
  • Replacement shear pins (OEM recommended)
  • Socket wrench
  • Pliers
  • Safety gloves
Additionally, wearing safety gloves is important to protect your hands from sharp edges or cold metal parts while you work on your snow blower.
Step-by-Step Shear Pin Replacement Process
  1. Identify the broken shear pin location.
  2. Remove the broken pieces using pliers.
  3. Align the auger holes with the shaft.
  4. Insert the new shear pin.
  5. Tighten the securing nut, avoiding over-tightening.
Common Mistakes When Replacing Shear Pins
Over-Tightening the Shear Pin
Over-tightening can lead to unnecessary stress on the pin, causing it to break prematurely.
Using Incorrect Pin Sizes
Incorrect sizes may not fit properly, leading to operational issues or potential damage.
How Often Should You Check Your Shear Pins?
Seasonal Checks
Inspect your shear pins before the snow season starts.
During Heavy Snowfall Periods
Check them periodically during heavy snow to ensure they are intact.
Troubleshooting Shear Pin Issues
Auger Still Not Spinning After Replacement
This may indicate an internal gearbox issue requiring professional inspection.
Shear Pins Keep Breaking Frequently
Frequent breakage may indicate obstructions in your clearing path or the use of incorrect shear pins.
You can contact Yarbo's 24/7 customer support if you need assistance while replacing a shear pin on your Yarbo.
Maintaining Your Snow Blower for Optimal Shear Pin Performance
Lubrication Points to Check
Keep the auger shaft and gearbox adequately lubricated to reduce stress on shear pins.
Storage Tips After Snow Season
Store your snow blower in a dry, covered area and perform a final inspection on shear pins to prepare for the next season.
A shear pin might look like a tiny component, but it plays a significant role in maintaining your snow blower's health and performance. Regular checks, proper maintenance, and timely replacements can save you from costly repairs and ensure your snow blower operates efficiently throughout the winter season.
  1. What is a shear pin in a snow blower?
    It’s a safety component that connects the auger to the drive shaft and breaks when the auger hits a hard object, preventing damage.
  2. How do I know if my shear pin is broken?
    Your auger will stop spinning while the engine is running, or you may notice missing pins on the auger shaft.
  3. Are shear pins universal for all snow blowers?
    No, it is best to use OEM shear pins specific to your model for optimal performance.
  4. How often should I replace shear pins?
    Replace them immediately upon breakage; keep spares to ensure uninterrupted operation during the snow season.
  5. Can I use bolts instead of shear pins?
    No, using bolts can damage your snow blower, as they will not break under stress like shear pins.
  6. Where can I buy shear pins for my snow blower?
    You can purchase them from your snow blower’s manufacturer, local hardware stores, or online retailers like.
Regular price $5,999.00 USD
Regular price $8,199.00 USD
Regular price $9,299.00 USD
