Home Edge & Detail Trimming
Trimmer
Shop All Trimming Products
Achieve clean edges and precise trimming with a robotic solution designed to reach where mowers can't. Automated lawn trimmer for borders and hard-to-reach areas. No missed spots. No manual trimming. Just a flawless finish.
Free Fast Delivery
30 Days Free Returns
8 Item(s) Found
HOW YARBO WORKS
Yarbo uses its PPVS navigation system — integrating RTK-GPS, computer vision, odometry, and IMU sensors — to trim your lawn wire-free and on schedule, and switches to a snow blower or leaf blower
on the same Core when the season changes.
Set Up Once. Trim All Season.
  1. Set Up RTK Positioning
    Install the RTK base station in your yard, or use Net RTK if your area has network coverage — no base station needed.
  2. Map Your Zones in the App
    Open the Yarbo app and draw your fence lines, garden borders, and driveway edges directly on a satellite map. Adjust trimming zones anytime as your yard layout changes.
  3. Yarbo Gets to Work
    The Trimmer module pairs with your Lawn Mower, Snow Blower, or Blower module on the same Core — swap based on the season, no extra equipment to store or buy.
WHICH TRIMMER PACKAGE IS RIGHT FOR YOU?
All Trimmer Packages are currently out of stock. Use the guide below to find the right combination for your yard — then join the waitlist to get notified when it's back.
if you want autonomous debris clearing paired with precision edge finishing.
Need more than one?
The Trimmer module can be paired with any combination of the Lawn Mower, Snow Blower, and Blower modules — see available bundles to build a system that covers your whole yard, all year.
ROBOT TRIMMER vs. TRADITIONAL METHODS
Is Yarbo Trimmer the right fit? Here's how autonomous trimming compares to the alternatives.
Feature Yarbo Handheld Trimmer Trimming Service
Time added per mow None30–60 minutesNone
Recurring cost One-time investmentFuel/battery costsPer-visit or seasonal fees
Scheduling App-controlledManual, whenever you get to itSet by provider, not always immediate
Year-round use Yes (modular)Trimming season onlyVaries by service contract
Skipping edge trimming is easy when time is short, but the borders show it first. See how the Yarbo Trimmer module compares to doing it yourself or paying someone else to.
Beyond Edge Trimming: Year-Round Yard Care
Yarbo isn't just a trimmer — it's a modular platform for complete yard care automation. The Yarbo Core is designed to work with multiple modules:
  • Trimmer Module - Precise borders, fence lines, and hard-to-reach areas edge trimming
When your yard needs clean, well-defined lawn edges, heavy-duty mowing, winter snow removal, and seasonal debris clearing, Yarbo's modular system is designed to support every season. One Core with interchangeable modules helps simplify year-round yard care while reducing the need for separate seasonal equipment.
Products Features
Support & Care
Yarbo uses its PPVS navigation system — integrating RTK-GPS, computer vision, odometry, and IMU sensors — to follow your fence lines, garden borders, and driveway edges autonomously — no boundary wires needed. Map your trimming zones once in the app and Yarbo maintains them on schedule. Unlike single-purpose trimmers, Yarbo is a modular platform: the Trimmer runs on the same Core as the Lawn Mower, Snow Blower, and Leaf Blower — swap modules as the season changes, no extra machines to buy or store.
A lawn mower handles open grass areas, but it can't get close to fence lines, garden beds, or driveway edges without risking damage. A lawn trimmer is designed specifically for those finishing details — the borders and hard-to-reach areas that help give a lawn a more finished appearance. The Yarbo Trimmer handles that final layer of precision that mowing alone can't deliver.
Unlike a handheld trimmer that requires you to walk every edge by yourself, the Yarbo Trimmer uses RTK-GPS navigation — no boundary wires, no physical markers. Map your trimming zones once in the Yarbo App, and it follows those defined edges autonomously from there. Zones can be adjusted anytime as your yard layout or priorities change.
Yes. As a robot, the Yarbo Trimmer works across varied outdoor environments — fence lines, garden borders, driveway edges, and irregular terrain that a handheld trimmer takes far longer to cover manually. Map multiple trimming zones in the app and manage each area independently, so it works through your property systematically rather than requiring you to move section by section.
Manual trimming typically adds 30 minutes to an hour onto every mow — a task that gets skipped when time is short and shows immediately in how the lawn looks. The Yarbo Trimmer, as an autonomous robot, runs on a set schedule and maintains consistent edge definition throughout the season with minimal manual trimming.
Yes, and it's designed to. The Trimmer module attaches to the same Core unit as the Lawn Mower module — one robot handles both open-area mowing and precision edge trimming by swapping modules as needed. No separate machines, no manual follow-up after each mow.
Edge trimming is one of the most time-consuming finishing tasks in lawn care, and one of the easiest to let fall behind. Pairing the Trimmer module with your Yarbo Core keeps borders consistently defined on a schedule you set, without adding to your weekend workload — extending what your existing robot can do rather than introducing a separate tool.
  • Weather conditions
  • Carrier issues
  • High seasonal demand
  • Email: support@yarbo.com
  • Phone: +1 (631) 818-1850
  • Yarbo App support system
Own Your Yarbo Sooner
with 0% Financing and
flexible payment plans
Fast DELIVERY
Flexible Payment Options
30-Day Trial
