Yarbo Y40 vs. Y40P: Key Differences and Which Core to Choose
Reviewed by Yarbo Team
Published:
The biggest difference between the Yarbo Y40 and Y40P is their drive system. The Y40 features Brushed Drive Motors, while the Y40P features Brushless Hub Motors for faster movement, smoother handling, reduced motor wear, and a more refined driving experience.
Choose the Y40 if you want a capable, year-round yard robot at a lower upfront price. Choose the Y40P if your property has demanding terrain, requires frequent maintenance, or you place greater value on working efficiency, motor durability, and quieter drive operation.
Both are designed for large properties and share the same modular platform, battery capacity, navigation technology, towing capacity, and compatible Y Series modules.
This guide compares their specifications, drive systems, positioning options, and performance across snow, lawn, and leaf seasons to help you decide which Core is right for your property.
What Stays the Same
Think of the Core as the drive and navigation platform, and the modules as interchangeable working attachments. Both the Y40 and Y40P share the following capabilities:
  • Modular design: Both support compatible Y Series modules for lawn mowing, snow removal, leaf cleanup, and edge trimming.
  • Battery capacity: Both use a 36 V, 38.4 Ah (1.38 kWh) lithium-ion battery.
  • Tracked platform: Rubber tracks provide traction and stability on suitable slopes and uneven terrain.
  • Navigation: Both use Yarbo's PPVS multi-sensor navigation system, combining NetRTK and RTK positioning, vision, IMU, and odometry without requiring physical boundary wires.
  • Obstacle detection and avoidance: Both use AI vision and bumpers to help detect and respond to obstacles within their working areas.
  • Autonomous operation: Map your work zones in the Yarbo App, configure schedules, and let the robot follow its planned routes.
  • Automatic recharging: Both can return to the docking station when the battery runs low, recharge, and resume unfinished tasks. Charging from 20% to 80% takes approximately 90 minutes.
  • Towing capacity: Both have a rated gross trailer weight (GTW) capacity of up to 500 lbs, subject to suitable equipment and operating conditions.
  • Operating temperature: Both Cores have a specified operating temperature range of -13°F to 113°F (-25°C to 45°C).
The Y40P does not use a larger battery or a different set of working modules. Its main performance advantages come from its upgraded drive system.
Explore the Collection
Yarbo Y40 vs. Y40P at a Glance
Feature Yarbo Y40 Yarbo Y40P
Product positioning Standard Y Series Core High-performance Y Series Core
Drive system Brushed Drive Motors Brushless Hub Motors
Motor wear characteristics Carbon brushes are subject to wear No carbon brush wear
Drive noise characteristics Conventional brushed motor sound Reduced high-frequency mechanical drive noise
Maximum driving speed 0.65 m/s (1.5 mph) 1.2 m/s (2.7 mph)
Core dimensions (L × W × H) 26.6 × 22.3 × 20.2 in (675 × 566 × 512 mm) Same
Core weight, including battery 123.5 lbs (56 kg) Same
Battery capacity 36 V / 38.4 Ah (1.38 kWh) Same
Charging time (20%–80%) Approximately 90 minutes Same
Navigation NetRTK, local RTK, vision, IMU, and odometry Same
Obstacle detection and avoidance AI vision and bumpers Same
Rated towing capacity (GTW) Up to 500 lbs (226 kg) Same
Core water resistance IPX5 Same
Operating temperature -13°F to 113°F (-25°C to 45°C) Same
Snow coverage per charge (1 in of snow) Up to 6,000 sq. ft. Up to 7,000 sq. ft.
Snow Blower Module Gen 2 Two-stage, 24-inch clearing width, 12-inch intake height Same module
Snow-removal slope rating Up to 36% (20°) Same
Lawn Mower Pro Module 20-inch cutting width, 0.8–4.0-inch cutting height, dual 300W cutting motors Same module
Mowing coverage per charge Up to 0.25 acres Up to 0.3 acres
Mowing coverage per day Up to 1.7 acres Up to 2 acres
Maximum supported lawn area (twice-weekly mowing) Up to 6 acres Up to 7 acres
Mowing slope rating Up to 70% (35°) Same
Blower Module 21 N blowing force, 607 CFM, 174 MPH Same module
Trimmer Package compatibility Supported Supported
NetRTK service Free for the lifetime of the device Same
Complimentary 4G service period (eligible configurations) 2 years Same
Warranty 2-year limited warranty; optional extension up to 5 years of total coverage for eligible purchases Same
Snow blower package MSRP C$8,499 C$10,699
Availability Check the product page for estimated delivery Check the product page for estimated delivery
Notes:
  • Dimensions and weight: These figures apply to the Core with its battery, not the complete robot with a working module attached.
  • Performance: Snow coverage figures are based on 1 inch of snow and a full battery-capacity reference condition. Actual coverage during automatic recharge cycles may be lower. Mowing coverage depends on terrain, grass conditions, operating settings, and charging requirements.
  • Driving speed and noise: Maximum driving speed does not represent actual mowing or snow-clearing speed. Drive noise characteristics do not represent the total operating noise of an attached working module.
  • 4G service: Complimentary service periods apply to eligible configurations equipped with a 4G Connect Kit and begin upon applicable device activation. Check the relevant product specifications and service terms.
  • Pricing: Regular U.S. list prices as of November 24, 2026, before applicable taxes and promotional discounts. Check the Y40 and Y40P product pages for current prices, package contents, and delivery estimates.
Based on Yarbo internal testing under standard test conditions. Actual performance may vary depending on conditions.
Drive System, Noise and Maintenance
The main hardware difference between the Y40 and Y40P is their drive system. Both share the same tracked platform, battery capacity, navigation technology, and compatible Y Series modules, but their motor designs offer different driving characteristics.
Y40: Brushed Drive Motors
The Y40 features Brushed Drive Motors with a maximum driving speed of 0.65 m/s (1.5 mph).
Its drive system is designed for large residential properties, including lawns with slopes, uneven terrain, and dense grass, as well as driveways that require regular snow removal.
If the Y40 meets your property's maintenance needs, it offers the same essential modular functionality as the Y40P at a lower upfront price.
Y40P: Brushless Hub Motors
The Y40P features Brushless Hub Motors with a maximum driving speed of 1.2 m/s (2.7 mph).
Compared with the Y40's brushed motor design, the Y40P offers several advantages:
  • Higher driving speed: Helps improve movement efficiency across large properties and between work zones.
  • Smoother handling: Provides improved motion control on uneven ground and demanding terrain.
  • Reduced motor wear: The brushless design eliminates carbon brush wear, which can contribute to longer motor service life.
  • More refined drive noise: Reduces the high-frequency mechanical noise associated with carbon brush friction, resulting in a smoother, less intrusive driving sound.
The difference in drive noise is not necessarily reflected in a substantially lower overall decibel rating. The attached working module, terrain, and operating conditions also influence total operating noise.
The Y40P is particularly worth considering if you maintain a large or complex property, use your Yarbo frequently throughout the year, or prioritize working efficiency, motor durability, and quieter drive operation.
Positioning and Connectivity: RTK vs. NetRTK
Both the Y40 and Y40P use the same underlying navigation technology. Yarbo's PPVS system combines RTK positioning, binocular vision, IMU, and odometry to help maintain positioning when individual sensor signals are limited.
This multi-sensor approach supports navigation around trees, buildings, and other areas where satellite signals may be partially obstructed. Actual positioning performance depends on the environment and system configuration.
Both Cores support local RTK and NetRTK positioning. If you prefer local RTK positioning or NetRTK coverage is unavailable at your property, a compatible Data Center can be purchased separately.
Yarbo's NetRTK service is free for the lifetime of the device, subject to network coverage and internet connectivity requirements. Check availability at your address on the Yarbo NetRTK page.
For eligible configurations equipped with a 4G Connect Kit, both the Y40 and Y40P include two years of complimentary 4G service.
After the complimentary period, you can choose to renew the service to retain 4G-dependent features. Compatible Wi-Fi and Wi-Fi HaLow connectivity options remain available, depending on your setup.
Snow Season: Where the Cores Differ
Both the Y40 and Y40P use the same Snow Blower Module Gen 2, featuring:
  • A two-stage auger and impeller system
  • A 24-inch clearing width
  • A 12-inch intake height
  • An adjustable throwing distance of 6–40 feet
  • Dedicated snow tracks for winter traction
  • A snow-removal slope rating of up to 36% (20°)
The difference in snow-clearing performance comes primarily from the Core's drive system and working coverage.
Coverage Per Charge
Yarbo rates the Y40 at up to 6,000 sq. ft. and the Y40P at up to 7,000 sq. ft. in 1 inch of snow under its full battery-capacity reference condition.
The Y40P provides approximately 17% more published snow-clearing coverage under the same reference condition, despite having the same battery capacity and Snow Blower Module.
These figures do not represent guaranteed coverage during every automatic charging cycle. Deeper, wetter, or denser snow can reduce runtime and clearing coverage on both models.
If you have a long driveway or multiple snow-clearing zones, the Y40P offers additional working capacity, while both models support automatic recharging and task resumption.
Driving Speed and Movement
The Y40P's maximum driving speed is 1.2 m/s, compared with 0.65 m/s on the Y40.
Its upgraded drive system supports smoother movement and improved motion control, which can be particularly useful on larger driveways and properties with multiple clearing zones.
However, maximum driving speed is not the same as actual snow-clearing speed. Working speed depends on snow depth, density, clearing settings, and terrain.
Slopes and Uneven Terrain
Both models are rated for snow removal on slopes up to 36% (20°).
Yarbo's snow tracks feature anti-slip studs, and optional Weighted Side Plates can help improve stability and traction on suitable sloped terrain.
The Y40P's Brushless Hub Motors offer improved motion control on uneven winter terrain, but both Cores have the same published snow-removal slope limit.
Actual traction depends on snow, ice, and surface conditions.
Gravel Driveways
Both configurations support adjustable snow intake height. On suitable gravel driveways, raising the intake approximately 2 inches above the ground can help reduce the risk of picking up loose stones.
This adjustment does not eliminate the possibility of gravel entering or being thrown by the snow-clearing mechanism.
For heavy storms on either Core, Yarbo recommends clearing early and regularly rather than waiting for snow to pile up. The 12-inch intake height describes the size of the snow opening, not a guarantee that every 12-inch accumulation can be cleared in one pass.
Not sure how much snow-clearing capacity your driveway needs? Read What Size Snow Blower Do I Need?.
For properties with multiple clearing zones, see Yarbo's path optimization guide.
Compare both configurations in the Robotic Snow Blower collection.
Lawn Season: Same Mower, Different Drive Systems
Both the Y40 and Y40P support the same Lawn Mower Pro Module, designed for large lawns and demanding mowing conditions, including thick and dense grass.
Its shared specifications include:
  • Cutting motors: Dual 300W motors
  • Cutting width: 20 inches
  • Cutting height: Adjustable from 0.8 to 4.0 inches
  • Cutting system: Dual cutting discs with compatible blade options
  • Reference operating time: Approximately 120 minutes per working cycle
  • Module water resistance: IPX6
  • Obstacle detection and avoidance: AI vision and bumpers
Both Cores support scheduled mowing, automatic recharging, and task resumption.
What differs is how much ground each Core can cover, according to Yarbo's official Y40 Lawn Mower Pro and Y40P Lawn Mower Pro product specifications.
Mowing Coverage Y40 Y40P
Per charge Up to 0.25 acres Up to 0.3 acres
Per day Up to 1.7 acres Up to 2 acres
The maximum supported lawn area refers to the lawn size that each configuration is designed to maintain on a twice-weekly mowing schedule, rather than the area covered in a single charge or working session.
The Y40 is capable of maintaining large residential lawns within its published coverage limits. For particularly large lawns or more demanding mowing schedules, the Y40P offers higher published coverage and smoother drive operation.
Both configurations are rated for mowing on slopes up to 70% (35°) and support obstacle traversal up to 2 inches (50 mm), subject to suitable terrain and operating conditions.
The Y40P's Brushless Hub Motors are designed to provide smoother handling on slopes, uneven ground, and challenging lawn surfaces without increasing the published maximum slope rating.
Actual mowing coverage and performance vary with grass density, terrain, cutting height, operating settings, and charging requirements.
Thinking about replacing a riding lawn mower? See Yarbo vs. Riding Lawn Mowers.
Leaf and Edge Season: Shared Modules
Blower Module
Both Cores support the same Blower Module for clearing leaves and light yard debris from lawns, driveways, walkways, and patios.
Its published specifications include:
  • Blowing force: 21 N
  • Air volume: 607 CFM
  • Air velocity: 174 MPH
  • Motor power: 2,000 W
  • Reference operating time: Approximately 70 minutes
  • Light snow removal: Up to 2 inches of fresh, dry snow
The Blower supports different working patterns, including Path Mode for covering larger areas and Spiral Mode for gathering leaves into a more manageable pile.
For best results, clear leaves when they are dry. Wet or compacted leaves can be more difficult to move with airflow alone.
Both the Y40 and Y40P deliver the same published blowing force and airflow specifications. Their different drive systems may affect movement and overall working efficiency, but the Blower Module itself is identical.
You still need to collect or dispose of the leaves after they have been gathered.
Trimmer Package
The Trimmer Package complements the Lawn Mower Pro by helping maintain lawn edges, fence lines, and areas around obstacles that may be difficult for the mower to reach.
Its features include:
  • An adjustable trimming height from 2 to 4 inches
  • Nine height settings in 0.25-inch increments
  • Automatic trimming line feeding
  • A floating suspension design that helps the trimming head adapt to uneven edges and surface transitions
The Trimmer can work alongside a compatible Lawn Mower Pro Module for combined mowing and edge trimming. A standalone trimming configuration is also supported when paired with the compatible Smart Assist Module and required mounting equipment.
Both the Y40 and Y40P support compatible trimming configurations.
As of November 2026, the Trimmer Package is available for pre-order, with estimated deliveries beginning in January 2027. Check the Trimmer Package product page for the latest availability and configuration requirements.
Beyond Seasonal Yard Care: Towing and Smart Assist
The Y40 and Y40P share the same modular platform, which supports additional tasks beyond snow removal, mowing, and leaf cleanup.
Towing and Transport
Both Cores have a rated towing capacity of up to 500 lbs (gross trailer weight).
With suitable towing equipment, you can move compatible garden carts, lawn rollers, spreaders, and other yard implements without purchasing a separate powered platform for these tasks.
Always follow the applicable towing, load, attachment, and terrain limits.
The optional Smart Assist Module (SAM) adds features such as Follow Me and Auto Patrol.
  • Follow Me: Uses vision-based tracking to follow you at a safe distance during suitable yard tasks.
  • Auto Patrol: Supports scheduled property monitoring and unusual activity alerts.
The Smart Assist Module is sold separately for both the Y40 and Y40P.
Neither Core requires an upgrade to the Y40P to access these shared modular capabilities.
Explore compatible equipment in the Modules collection.
Which One Fits Your Yard?
The right Core depends on your property size, terrain, workload, positioning requirements, and budget.
Your Situation Recommended Core Why
You want a capable year-round yard robot at a lower upfront price Y40 Supports the same modular platform, battery capacity, navigation, and compatible working modules
You have a large driveway or multiple snow-clearing zones Y40P Higher published snow coverage per charge and maximum driving speed
You maintain a particularly large lawn or follow a demanding mowing schedule Y40P Higher daily mowing coverage and maximum supported lawn area
Your property has uneven ground, slopes, or demanding terrain Y40P Brushless Hub Motors offer smoother movement and improved motion control within published slope limits
You prioritize quieter drive operation Y40P Reduced high-frequency mechanical drive noise
You want to reduce motor wear associated with carbon brushes Y40P Brushless motor design eliminates carbon brush wear
You prefer a base-station-free setup Either Both support NetRTK where coverage and connectivity are available
You mainly need modular flexibility for different seasons Either Both support the same compatible Y Series modules
You need your Yarbo before a particular date Check both Availability and delivery estimates may differ between configurations
Still unsure? Consider these five questions:
  1. How much lawn and driveway area do you need to maintain?
  2. How steep or uneven is your property?
  3. How frequently will you use your Yarbo throughout the year?
  4. How important are drive motor durability and quieter operation to you?
If the Y40 already meets your property's requirements, its lower upfront price makes it a practical choice. If you need greater working coverage, smoother drive performance, and reduced motor wear associated with carbon brushes, the Y40P may be worth the additional investment.
The Yarbo Y40 and Y40P are built on the same modular platform for large properties. Both offer year-round yard care, autonomous navigation, automatic recharging, and compatibility with the same Y Series modules.
The Y40 delivers these capabilities at a lower upfront price, making it a strong choice if its working coverage and drive performance meet your property's needs.
The Y40P builds on the same platform with Brushless Hub Motors, offering higher maximum driving speed, greater published working coverage, smoother handling, reduced carbon brush-related wear, and a more refined driving sound.
The decision is not about which Core supports more seasonal tasks. It is about how much drive performance and working efficiency you need, and whether those advantages justify the additional cost for your property.
Compare the latest configurations and prices for the Yarbo Y40 and Yarbo Y40P, or explore the full Yarbo product collection.
What Is the Main Difference Between the Yarbo Y40 and Y40P?
The main hardware difference is the drive system.
The Y40 features Brushed Drive Motors with a maximum driving speed of 0.65 m/s, while the Y40P features Brushless Hub Motors with a maximum driving speed of 1.2 m/s.
Both share the same Core dimensions, battery capacity, navigation technology, rated towing capacity, and compatible Y Series modules.
The Y40P offers higher published mowing and snow-clearing coverage, smoother movement, reduced motor wear associated with carbon brushes, and less high-frequency mechanical drive noise.
Is the Yarbo Y40P Worth the Extra Cost?
The Y40P may be worth the additional cost if you have a large or complex property, need higher working coverage, use your robot frequently, or prioritize smoother and quieter drive operation and motor durability.
If the Y40 already meets your property's requirements, it provides the same essential year-round modular functionality at a lower upfront price.
Can I Use the Same Modules on Both Cores?
Yes. Both the Y40 and Y40P support the same compatible Y Series Snow Blower Module Gen 2, Lawn Mower Pro Module, Blower Module, Trimmer Package, and optional Smart Assist Module.
Individual modules and accessories may have specific installation or compatibility requirements. Check the applicable product information before purchasing.
Does the Y40P Have a Larger Battery Than the Y40?
No. Both Cores use a 36 V, 38.4 Ah (1.38 kWh) battery.
The Y40P offers higher published working coverage without requiring a larger battery.
Both models support automatic recharging and have a published charging time of approximately 90 minutes from 20% to 80%.
Do the Y40P's Brushless Hub Motors Last Longer?
The Y40P's Brushless Hub Motors eliminate the carbon brushes found in conventional brushed motors, removing a common source of mechanical wear.
This design can contribute to longer motor service life. However, actual durability depends on workload, operating conditions, maintenance, and other components of the drive system.
Brushless motors are not entirely free from wear or maintenance requirements.
Is the Y40P Quieter Than the Y40?
The Y40P's Brushless Hub Motors reduce high-frequency mechanical noise associated with carbon brush friction, resulting in a more refined driving sound.
However, total operating noise also depends on the attached module, terrain, and working conditions. The difference in drive noise does not necessarily translate into a substantially lower overall decibel rating during every task.
Is the Y40P Faster at Clearing Snow?
The Y40P has a higher maximum driving speed and greater published snow-clearing coverage per charge.
In 1 inch of snow, its published coverage is up to 7,000 sq. ft., compared with 6,000 sq. ft. for the Y40 under the same reference condition.
Both use the same Snow Blower Module Gen 2, with identical clearing width, intake height, and throwing distance specifications.
Actual job completion time depends on snow depth, density, clearing routes, operating settings, and charging intervals.
Does the Y40P Handle Steeper Slopes Than the Y40?
No. Both models have the same published slope ratings: up to 70% (35°) for mowing and 36% (20°) for snow removal.
The Y40P's Brushless Hub Motors are designed to improve movement and control on demanding terrain, but they do not increase the published maximum slope rating.
Actual traction depends on surface and operating conditions.
Does Yarbo Require a Subscription?
Yarbo's NetRTK positioning service is free for the lifetime of the device, subject to network coverage and connectivity requirements.
For eligible configurations equipped with a 4G Connect Kit, both the Y40 and Y40P include two years of complimentary 4G service. You can choose to renew the cellular service after the complimentary period.
Whether you need continued 4G service depends on your network setup and the features you use. See Yarbo's connectivity service policy for details.
Can I Switch From a Y40 to a Y40P Later?
Both models support compatible Y Series working modules, so those modules can be used with either Core.
However, do not assume that a Core upgrade, trade-in, or exchange program is available. Contact Yarbo Support to confirm available upgrade options, accessory compatibility, and any additional equipment requirements before purchasing a replacement Core.
Sources
Product specifications, regular U.S. list prices, and availability information are based on November 2026 product information. Refer to the official product pages for the latest information.
Regular price $4,899.00 USD
Regular price $6,499.00 USD
Regular price $7,399.00 USD
