Home Snow Removal
Robotic Snow Blower
Shop All Snow Removal Products
A Yarbo robotic snow blower clears driveways, walkways and sidewalks automatically, on a schedule or as soon as snow starts, and recharges itself between runs. Every setup pairs a Yarbo Core with the Snow Blower Module Gen 2. Compare the Y40 and Y40P Cores below, then choose modules for the rest of the year.
Free Fast Delivery
Up to 5-Year Warranty
15 Item(s) Found
HOW YARBO WORKS
Yarbo works as an automatic snow blower: it follows the zones you map in the app, with no boundary wires.
Set Up Once. Clear All Winter.
  1. Set up positioning.
    Install the RTK base station before the season starts, or use NetRTK if your area has network coverage — no base station needed.
  2. Map your zones.
    Map driveways, walkways and sidewalks in the Yarbo app, then set the order, intake height, throw direction and schedule for each.
  3. Start clearing.
    Yarbo can start when snow begins, run on a schedule, or start from the app. Clearing during a storm keeps snow below the 12-inch intake height.
  4. Recharge and resume.
    At about 20% battery, Yarbo docks, recharges to about 80% in roughly 1.5 hours, and picks up where it left off.
  5. When you may need to step in: Curb piles left by street plows may need an extra pass or a shovel, and heavy, wet snow is best handled with the optional plow blade. Keep cars and hoses out of mapped zones.
WHICH ROBOTIC SNOW BLOWER IS RIGHT FOR YOU?
1. Compare Y40 and Y40P for Snow Removal
Feature Y40 Core + Snow Blower Module Gen 2 Y40P Core + Snow Blower Module Gen 2
Snow blower module Snow Blower Module Gen 2Same
Clearing 2-stage, 12" intake height, 24" clearing widthSame
Throw distance and control Up to 40 ft; deflector -5° to 50°, chute -10° to 190°Same
Drive system Brushed Drive MotorsBrushless Hub Motors
Mapping and turning StandardFaster mapping, smoother turning
Coverage per charge Up to 6,000 ft²Up to 7,000 ft²
Slope rating Up to 36% (20°)Same
Operating temperature -13°F to 113°F (-25°C to 45°C)Same
Data Center in the box IncludedNot included
Coverage per charge is measured in 1 inch of snow. Prices reflect current pricing for each snow removal setup.
2. Which Core Fits Your Snow-Clearing Needs?
Choose Y40 if:
You want the same clearing width, depth and throw distance as the Y40P for a lower price.
Your driveway and paths fit within about 6,000 ft² per charge. Larger areas still get cleared,
with more recharge stops.
You want the Core with the longest track record among Yarbo owners.
Choose Y40P if:
You have a long driveway or large property. Up to 7,000 ft² per charge means fewer recharge stops.
You want smoother handling on snow, ice and uneven ground, thanks to dual hub motors.
You want faster mapping and fewer interruptions while clearing.
Steep driveway? Both Cores are rated for slopes up to 36% (20°), so slope alone doesn't decide between them.
Year-round use: The Y40P's upgrades are built into the Core, so they also apply to mowing, leaf cleanup and trimming. Compare both Cores for mowing on our robot lawn mower page.
3. Choose the Modules for Your Property
Choose modules by the jobs you need done. Every setup below includes the Core and the Snow Blower Module Gen 2; other modules are sold separately on our modules page.
Your needs Modules What it adds Y40 setup Y40P setup
Snow removal only Snow BlowerAutonomous clearing for driveways, walkways and sidewalksShop Y40Shop Y40P
Snow and mowing Snow Blower + Lawn Mower ProAutonomous mowing from spring to fall on the same CoreShop Y40Shop Y40P
Snow and leaf cleanup Snow Blower + BlowerClears leaves and debris from lawns, driveways and pathsShop Y40Shop Y40P
Snow, mowing and leaf cleanup Snow Blower + Lawn Mower Pro + BlowerCovers winter, the mowing season and fall cleanupShop Y40Shop Y40P
Snow, mowing and edge trimming Snow Blower + Lawn Mower Pro + TrimmerThe mower cuts open lawn; the Trimmer finishes edges and bordersShop Y40Shop Y40P
Every yard job Snow Blower + Lawn Mower Pro + Blower + TrimmerSnow removal, mowing, leaf cleanup and edge trimmingShop Y40Shop Y40P
4. Do You Need Snow Accessories?
Most driveways need only a snow removal setup. Add these for specific conditions:
Snow Plow Blade (Y Series): Pushes heavy, wet snow aside with fewer clogs.
Anti-Slip Studs (Y Series): Replacements for the studded snow tracks included with both setups.
Weighted Side Plates (Y Series): Extra traction and stability on sloped driveways.
ROBOTIC SNOW BLOWER vs. TRADITIONAL METHODS
Here's how an automated snow blower like Yarbo compares with a walk-behind snow blower and a snow removal service, so you can decide what fits your driveway, your winters, and your schedule.
Feature Yarbo Traditional Snow Blower Snow Removal Service
Operation Autonomous after setupYou operate itA crew operates it
Your time per storm Minimal; step in for curb pilesA full session outsideNone, but you wait for the crew
When snow gets cleared During snowfall or on scheduleOnly when you're outside operating itDepends on crew availability
Upfront cost HigherLowerNone
Ongoing cost Electricity and upkeep; optional 4G planFuel, oil, tune-ups each seasonPer-visit or seasonal fees
Scheduling App-controlledManual, weather-dependentSet by provider, not always immediate
Maintenance Routine checks, track careEngine service each seasonSet by provider, not always immediate
Year-round use Yes (modular)Snow season onlySnow season only
Best for Frequent snowfallOccasional storms, lower budgetNot wanting to own equipment
Beyond Snow Removal: Year-Round Yard Care
The Core that clears your driveway in winter can mow, clear leaves and trim edges the rest of the year with the Lawn Mower Pro, Blower and Trimmer modules. Use the module guide above to match modules to your yard, or browse all Yarbo modules.
Products Features
Support & Care
Yarbo uses its PPVS navigation system — integrating RTK-GPS, computer vision, odometry, and IMU sensors — to navigate your driveway and walkways wire-free, even in snow-covered conditions. Map your clearing zones once in the app and Yarbo runs automatically — through the night if needed. Unlike most robot snow blower brands that build single-purpose machines, Yarbo is a modular platform: the same Core that clears your driveway all winter attaches to a Lawn Mower or Leaf Blower module when the season changes.
Yes. Modules are sold separately, so you can start with snow removal and add others later. Check each module's page for compatibility.
Yes. Once your zones are mapped, Yarbo can start when snow begins or on a schedule, return to recharge, and resume. You may still need to clear curb piles left by street plows.
Dry, packed and wet snow, on asphalt, concrete and gravel. For heavy, wet snow, add the plow blade; on gravel, raise the intake about 2 inches.
Both use the same Snow Blower Module Gen 2, so clearing width, depth and throw distance are identical. The Y40P uses Brushless Hub Motors for smoother handling, maps faster, and covers up to 7,000 ft² per charge versus 6,000 ft² for the Y40.
It is if you get several storms a season and currently spend time clearing snow or pay a service. If your driveway rarely gets significant snow, a traditional blower or an occasional service may be simpler.
Yes. On long driveways, Yarbo recharges and resumes; the Y40P covers more per charge (7,000 ft² versus 6,000 ft²). Both Cores are rated for slopes up to 36% (20°), and optional weighted side plates add stability on sloped driveways.
Yes. Add the Snow Blower Module Gen 2 to your Core instead of buying a second machine. Check compatibility on the module page, especially for earlier Cores.
The Lawn Mower Pro for mowing, the Blower for leaves and debris, and the Trimmer for edges. See the module guide above for every combination.
Choose the Y40 for the same snow performance at a lower price. Choose the Y40P for a long driveway or large property, smoother handling, or heavy year-round use. For unusual properties, contact Yarbo support before you buy.
  • Weather conditions
  • Carrier issues
  • High seasonal demand
  • Email: support@yarbo.com
  • Phone: +1 (631) 818-1850
  • Yarbo App support system
Own Your Yarbo Sooner
with 0% Financing and
flexible payment plans
Fast DELIVERY
Flexible Payment Options
30-Day Free Returns
30-Day Trial
up to 5-year Warranty
