  • Yarbo Lawn Mower Pro
    Made for the Wild Lawn
Pricing
Comparison
Video
Upgrades
Power in Action
- Lawn Mower Pro Performance
See how the Yarbo Pro effortlessly handles your lawn—so you don't have to.
Optional New Straight Blades
Pro packs two blade options: standard discs & blades and new Straight Blades, offering finer cuts, enhanced durability, and a cleaner, low-maintenance lawn.
Improved Performance-Yarbo Lawn Mower Pro
Greater Durability-Yarbo Lawn Mower Pro
Greater Durability
Efficient Mulching-Yarbo Lawn Mower Pro
Efficient Straight Blades
Yarbo Lawn Mower Pro-Yarbo Lawn Mower Pro
Smoother Operation
100% More Power
Pro packs dual 300W motors—twice the power of the standard 150W—and delivers up to 2500W peak for stronger, longer-lasting performance.
Heavy-Duty Mowing
Heavy-Duty Mowing—Yarbo Lawn Mower Pro
No More Clogging
No More Clogging-Yarbo Lawn Mower Pro
Reliable Auto-Operation
Reliable Auto-Operation——Yarbo Lawn Mower Pro
Engineered for Demanding Lawns
With 300W motors, straight blades, a cutting area of up to 6 acres and a cutting height down to 0.8 inches, Yarbo Lawn Mower Pro is built for residential, commercial, and tough grass conditions.
Yarbo Lawn Mower Pro for Residential use
Residential Use
Yarbo Lawn Mower Pro offers smart mowing for properties up to 6 acres. With its terrain-ready design, it’s well-suited for large and varied landscapes.
Yarbo lawn mower pro for commercial use
Commercial Use
Ideal for high-end commercial spaces and landscaping businesses. making it ideal for golf courses, turf farms, luxury hotels, resorts, and more.
Yarbo lawn mower pro for long and wild grass
Long and Wild Grass
Enhanced motor power and straight blades manage long, overgrown grass efficiently—minimizing clogging and delivering a clean, even cut.
Yarbo lawn mower pro for warm-season grass
Wet, Thick, Warm-Season Grass
The 300W motors power through wet, thick grass and dense warm-season grass, delivering a smooth, consistent cut even in tough conditions.
Mower Pro in the Spotlight
See what the press is saying.
“Yarbo's modular lawn maintenance devices make lawn care a breeze”
Yarbo is the world’s first multifunctional modular lawn robot, made up of one intelligent core device that powers interchangeable modules that do the hard work. What does that mean for you? Kicking back while your automated Yarbo system mows the lawn, trims the edges and clears away leaves and snow. The just dropped Lawn Mower Pro, the newest and coolest robotic lawn mower setup on the block. Best of all...
CNN
CNN
Coverage on Yarbo's New Product Launch
Learn More >
“The Yarbo Pro will be able to deliver a more consistent mow that’s more like a conventional lawnmower.”
The Yarbo Pro will be able to deliver a more consistent mow that's more like a conventional lawnmower. It'll also be able to handle more real world scenarios, like overgrown and wet lawns. I'm especially appreciative of that living in a place where it rains nearly every day, so my grass is always one or the other. What may deter you is...
Forbes
Forbes
Learn More >
To Help You Decide
Everything you need to know before making your purchase.
Shipping
Shipping
We're shipping the Yarbo Core, Docking Station, and Battery first—so you can start yard patrol and towing right away! Got a bundle? Available modules will also arrive within 3–8 business days. Lawn Mower Pro Module is expected to be delivered in January 2026, and the Trimmer package will be delivered in March 2026.
Activating only the Yarbo Core? That’s bonus time and doesn’t count toward your warranty. Your 2-year warranty starts on whichever comes first: the day you activate your first module (Snow Blower, Blower, or Lawn Mower Pro), or 3 days after your Yarbo Pro Module arrives.
30-Day Trial
30-Day Trial
7/24 Customer Support
Find answers to the questions that matter most to you!
What are key upgrades of Yarbo Lawn Mower Pro compared to Yarbo Lawn Mower?
Yarbo Lawn Mower Pro features dual 300W motors delivering 2500W peak power, new optional straight blades, and an enhanced cutting height range down to 0.8 inches (2 cm). With these upgrades, Yarbo Lawn Mower Pro excels in residential lawn care and expands its use to commercial applications. It’s perfect for both cool and warm-season grasses, as well as wet, thick, and long grasses.
When can I receive Yarbo Lawn Mower Pro?
Lawn Mower Pro Module is currently available for pre-order and the delivery is expected to start in January 2026. We are taking extra care to ensure each Yarbo Pro meets our rigorous quality standards before shipping. Existing products, including Yarbo Core, Snow Blower, and Blower, will be delivered within 3-8 business days.
How much area can the Mower Pro cover on a full charge? Why do both Yarbo Lawn Mower and Yarbo Lawn Mower Pro cover up to 6 acres?
Yarbo covers up to 0.43 acres on a full charge (from 100% to 0% battery). However, the recommended usage is between 80% to 20% battery, which is also the default charging setting. When operating between 80% and 20%, Yarbo covers about 0.25 acres per charge.
The mowing time for a charge from 80% to 20% is approximately 120 minutes, while the charging time from 20% to 80% is 90 minutes (please note that charging time may vary under low or high temperature conditions). In one day, Yarbo mows 7 cycles, each covering 0.25 acres, so it can cover up to 6 acres.
Both Yarbo Lawn Mower and Yarbo Lawn Mower Pro, using the same battery capacity, are designed to cover up to 6 acres.
What is the cutting height range of Yarbo Lawn Mower Pro? Why can it cut grass lower?
The cutting height range of Yarbo Lawn Mower Pro is adjustable from 0.8 to 4.0 inches (2-10 cm). The ability to cut grass lower is due to the mower's blades being able to press down further. As the grass root becomes denser and thicker, it requires a more powerful mower. With dual 300W motors, Yarbo Lawn Mower Pro is designed to handle this more demanding task with ease.
What are the upgrades on the cutting discs and blades?
Yarbo Lawn Mower Pro comes with two sets of blades. One set features dual cutting discs, each equipped with 5 razor blades. These discs are reinforced to enhance durability and prevent clogging. The other set consists of two straight blades made from SK85 high-carbon steel, offering greater durability, strength.
What types of grass can Yarbo Lawn Mower Pro handle?
Yarbo Lawn Mower Pro is capable of handling all-season grasses, with particular ease when dealing with warm-season grasses. It can efficiently tackle grasses like Zoysia, Buffalo Grass, St. Augustine Grass, Bermuda Grass,and Kikuyu Grass, which are known for being dense, tough, and challenging to mow.
Will Lawn Mower Pro face clogging issues?
With the straight blades, grass clogging is not a problem; and the clogging issue has been significantly reduced with the new disc and blade design. By using a simplified fence structure and having the blades rotate outwards to eject the cut grass, best Robot Lawn Mower Pro efficiently prevents clogs.
I'm having trouble with initial setup and configuration—what should I do?
Lawn Mower Pro - Best Robot Lawn Mower for Wild Lawns
The Future of Yard Care
Specifications Specifications
Book A Demo
Specifications
Specifications
Setup and Installation
Installer Program
Submit a Ticket>
1 on 1 Video Instruction
Submit a Ticket>
