Robots
Latest
Bundles
Modules
Accessories
Zero-effort Yard Care for Every Season
Meet Yarbo — a leading modular yard robot system that manages various chores, from snow blowing to lawn mowing and leaf blowing. Experience the future of yard care, hands-free.
Lawn Mower
Max Coverage
20 in
Cutting Width
Applicable Slope
Blower
21 N
Blowing Force
Applicable Slope
Blower Module
70 mins
Operation Per Charge
Snow Blower
6 - 40 ft
24 in
12 in
31 acres
Internet Coverage
4 hrs
500 lbs
Towing Capacity
Shop Lawn Mower Pro & It's Bundle
Build your dream yard squad — from mowing and leaf blowing to snow removal, the Yarbo bundle has you covered all year round.
Select Your Modules That Fit Your Needs
Hear from Yarbo Community
They say good things come to those who are patient. I have been reminded of that with Yarbo. It was really difficult to wait but I will confess that the wait was totally worth it. Let's just start with the build quality, organization of packing, the tools (), and did I mention the build quality? I installed my Yarbo yesterday after spending a few hours on a lift. My setup is unique in that I have a barn on my property about 300 feet from my house. The DC is mounted on the barn and my Yarbo lives in my driveway at my house. Setup took the better part of the day, I tested connectivity in the extreme parts of my yard before making the install "permanent". I have 12 acres of property and my signal was strong well over 500 feet and elevation changes with plenty of obstructions. One thing I learned that I read from this group was the Halow can't penetrate earth so if you test on the ground be aware that elevation impacts! Another thing I discovered was the GPS/RTK antennas had a thin gasket that I believe was just enough of a gap that caused low GPS signals. I removed the gaskets and re-seated them and improved my signal. Will need to revisit this. I have my docking station next to the brick wall (may need to revisit this location) and used the grass spikes to attach it to the pavement. Yes it worked! First off the spikes are not cheaply made. They remind me of GRK fastener quality. Also, Yarbo thought to provide you with a driver tool which again (like the 12mm driver tool) was of high quality. You can really tell this unit was packaged thoughtfully. Great work! Once everything was paired up I attached my mower attachment and set off to map a small section of my yard. After easily doing that and setting all the fun settings I sent Yarbo back to the DS and told it to start the plan. FLAWLESSLY it navigated and mowed the entire section leaving some wonderful stripe marks that filled my heart with joy . After it finished and on nearly 100% charge it FLAWLESSLY returned to the docking station and recharged. Wow, just wow. More testing to come, including my large circular driveway for snow blowing. They also say that first impressions are most important. Yarbo did not disappoint in that area either. Bravo Yarbo!
