robotic snow blower robotic snow blower
24/7 Autonomous Snow Clearing
with Auto-Recharging
No Snow Buildup — 24/7 Autonomous Clearing
Weather-triggered: when snow starts, Yarbo starts.
One-Time Setup. Season-Long Autonomy.
Draw your driveway once in the app—Yarbo robotic snow blower handles every storm automatically.
Auto-docks at ~20%, Resumes at ~80%.
38.4 Ah
Battery Capacity
-25°C to 60°C
Operation Temperature
1.25 h
Charging Time
Wider. Deeper. Faster.
12″ intake, 24″ clearing width—clears deep snow in layers.
Tackle Different Snow Types
Heavy slush?
Attach the plow blade to push through with fewer clogs.
Compacted layers?
The two-stage intake breaks it up and clears in passes.
Powder builds fast.
Weather-triggered runs start with the first flakes; 6–40 ft throw keeps edges clean.
Maximum Throwing Distance: 40ft
Fits Different Driveways
Large Driveway
24″ clearing width with adjustable 6–40 ft throw covers wide two-car lanes.
Large Driveway
Gravel Driveway
Raise the intake up to ~2″ to skim uneven gravel. The metal chute resists incidental gravel impacts.
Gravel Driveway
Circular Driveway
Turn on Spiral Mode—it circles the center for quick, even coverage on circular or semicircular layouts.
Circular Driveway
Sidewalks
Map multiple zones—paths, driveways, sidewalks. Clear several areas in one run.
Sidewalks
Multi-Zone Management
Map multiple zones in the app to match your property and adjust depth and schedule per zone.
Engineered for Durability & Efficiency
Two-stage system, reinforced steel chassis, anti-slip track drive, and flexible throwing angles for consistent results.
2-Stage Design
2-Stage Design
Built to Last
The robotic snow blower features durable Q355 steel construction with 355 MPa strength, operates in -25°C to 45°C (-13°F to 113°F), and carries an IPX5 waterproof rating for reliable performance.
Built to Last
Non-Slip Design
200+ lb track drive with traction spikes, deep-bite tread, and anti-slip control—built for grip on ice and slopes.
Traction Spikes
Traction Spikes
Bite into packed snow and icy ground to help maintain grip.
Tread Pattern
Tread Pattern
Wide, patterned tracks distribute weight and grip uneven, icy paths.
Non-Slip Design
Traction Spikes
Traction Spikes
Tread Pattern
Tread Pattern
Your Yard Deserves the Full Squad
Hear from Yarbo Community
With the robotic snow blower, it easily clears the snow berms left behind by the plow, when I want to.
"Day 4 of Yarbo robotic snow blower in Palmer Alaska and so far doing really good. The mapping was pretty complicated at times and there are some things it try's to hit but it has gotten better and better. I'm impressed"
I am very impressed with my yarbo robotic snow blower and the yarbo team! After lots of live events and Q&A sessions I decided to purchase mine this summer for my elderly grandparents. Today was the first real snowfall since set up and I am very pleased. Yes there were a few, and still are, some glitches but overall very impressive. It made it all worth it to know my grandparents are sitting in the comfort of their home while I watch yarbo clear their driveway from my house on my phone. The yarbo team has been awesome with answering any questions/helping with tech support too. Thank you yarbo and keep up the great work!
There is not much snow, but Yarbo is doing a great job! I was enjoying a cup of coffee and recording. I will adjust the auger to 0 so that the robotic snow blower can scrap the bottom nicely.
After the last set of software updates and a reboot of the datacenter and Yarbo robotic snow blower, everything worked. Strong signal and success in mapping and clearing fresh snow from my driveway. I have lots of trees in a suburban environment with lots of dwellings nearby so my location was not a textbook locating for Yarbo Tech support was great, the fit and finish of the unit was amazing butwas lookingat making a return because could not get my location work. If your have setup problems, I suggest working closely with Yarbo and being patient. Now that it's working it's a game changer.
They say good things come to those who are patient. I have been reminded of that with Yarbo. It was really difficult to wait but I will confess that the wait was totally worth it. Let's just start with the build quality, organization of packing, the tools (), and did I mention the build quality? I installed my Yarbo yesterday after spending a few hours on a lift. My setup is unique in that I have a barn on my property about 300 feet from my house. The DC is mounted on the barn and my Yarbo lives in my driveway at my house. Setup took the better part of the day, I tested connectivity in the extreme parts of my yard before making the install "permanent". I have 12 acres of property and my signal was strong well over 500 feet and elevation changes with plenty of obstructions. One thing I learned that I read from this group was the Halow can't penetrate earth so if you test on the ground be aware that elevation impacts! Another thing I discovered was the GPS/RTK antennas had a thin gasket that I believe was just enough of a gap that caused low GPS signals. I removed the gaskets and re-seated them and improved my signal. Will need to revisit this. I have my docking station next to the brick wall (may need to revisit this location) and used the grass spikes to attach it to the pavement. Yes it worked! First off the spikes are not cheaply made. They remind me of GRK fastener quality. Also, Yarbo thought to provide you with a driver tool which again (like the 12mm driver tool) was of high quality. You can really tell this unit was packaged thoughtfully. Great work! Once everything was paired up I attached my mower attachment and set off to map a small section of my yard. After easily doing that and setting all the fun settings I sent Yarbo back to the DS and told it to start the plan. FLAWLESSLY it navigated and mowed the entire section leaving some wonderful stripe marks that filled my heart with joy . After it finished and on nearly 100% charge it FLAWLESSLY returned to the docking station and recharged. Wow, just wow. More testing to come, including my large circular driveway for snow blowing. They also say that first impressions are most important. Yarbo did not disappoint in that area either. Bravo Yarbo!
Yarbo is solving some tremendously difficult problems in making a robotic snow blower, and I commend their efforts at solving many first-in-class issues. Video shows it doing a pretty good job on one of its longer straightaways. If it would do my whole driveway this way we'd really be revolutionizing my winters!
The Future of Yard Care
Specifications Specifications
Book A Demo
Specifications
Specifications
Setup and Installation
Installer Program
Submit a Ticket>
1 on 1 Video Instruction
Submit a Ticket>
robotic snow blower
