  • The Pioneering Autonomous Lawn Trimmer
    We are currently conducting extended field testing and performance calibration to ensure optimal long-term reliability across diverse terrains.
Leave your email to receive priority access when inventory becomes available.
Yarbo Trimmer Highlights
Hands-Free Trimming
Mowing is fun, but walking around the whole lawn trimming the edges? Let Yarbo trim while you relax. No need to hold or guide—just set it and forget it.
What You Draw, What You Get
For a lawn that's consistently well-trimmed, simply use memory path and let Yarbo deliver impressive results, precisely along the edges, just the way you want.
Hassle-Free Maintenance
Enjoy effortless upkeep with a trimmer that charges itself and only needs re-stringing about once a month—or longer, depending on lawn size and frequency of use. Yard care can be this simple.
Why Choose Yarbo Trimmer?
1 / 2
Breaking Down Yarbo Innovation
Automatic Line Feed
Smart Terrain Adaptation
The spring and floating-ball suspension design ensures the trimmer bounces back from obstacles and better follows uneven terrain, protecting your lawn and delivering more consistent cuts.
Adjustable Trimming Height
Your Yard Deserves the Full Squad
  • Can the trimmer be adjusted electronically?
    No, the trimmer's height adjustment is manual. It offers 9 selectable levels: 2.0, 2.25, 2.5, 2.75, 3.0, 3.25, 3.5, 3.75, and 4.0 inches.
  • What is the delivery ETA of the trimmer?
    We will share the full details of this plan, along with a finalized delivery schedule, by March 2026.
  • Will the trimmer cause bark damage?
    No, the trimmer has a guiding disc that rotates along the physical boundary of a wall, tree, or fence and covers the range of the trimmer line.
  • Can the trimmer be used together with the mower?
    Yes, the trimmer can be installed on the rear of Yarbo Core along with both the Yarbo Lawn Mower Module and Yarbo Lawn Mower Pro Module.
  • Does the trimmer line need to be specifically from Yarbo, or can we use other brands as well?
    The trimmer line diameter is 1.6 mm and is compatible with multiple line sizes (0.65 mm, 0.80 mm), so non-Yarbo lines of these diameters can also be used.
  • Can the trimmer be used to trim around headstones in a cemetery?
    Yes, the Yarbo Trimmer can trim around headstones in cemeteries with care and precision.
    It features flexible trimming lines covered by a protective disc, preventing damage to boundary objects.
    For best results, we recommend customizing the working area and trimming path in the app to ensure full coverage while avoiding contact with valuable surfaces like gravestones.
  • What happens if the trimmer line runs out?
    When the trimmer line runs out, users can quickly replace the entire spool or the line itself using the provided maintenance tool.
  • Can the trimmer be used vertically?
    The trimmer can't be used vertically.
Pre-order Now
Specifications Specifications
Specifications
Specifications
Setup and Installation
Installer Program
1 on 1 Video Instruction
Submit a Ticket>
Yarbo Trimmer – First Autonomous Lawn Trimmer
