How Often to Cut Grass for a Healthier Lawn
Jun 23, 2025 Buying Guides
Robot and traditional lawn mower side by side
How often to cut grass is one of the most common questions homeowners ask when aiming for a lush, green lawn. The answer isn’t one-size-fits-all it depends on your grass type, season, growth rate, and weather.
This guide breaks down how often to cut grass, ideal mowing heights, and lawn mower tips to help you maintain healthy turf year-round. Whether you're using a manual, gas, or robot lawn mower, sticking to a proper mowing schedule is key to vibrant lawn health.
What Factors Affect Your Lawn Mowing Frequency?
1. What Season Are You In?
  • Spring and early summer = Fast growth = More mowing
  • Fall and winter = Dormancy = Less mowing
2. How’s the Weather?
  • More rain = More growth
  • Drought = Less mowing, higher grass helps shade soil
3. How Much Foot Traffic Does Your Lawn Get?
High-traffic areas look worn faster and may need more frequent mowing for aesthetics.
4. How Low Are You Cutting?
Cutting lower requires more frequent mowing. Always stick to the one-third rule, which is not to cut 1/3 of the length of the blade at a time./
5. Is Your Lawn Fertilized or Irrigated?
A well-fed, regularly watered lawn will grow quicker and require more attention.
How Often to Cut Grass by Grass Type
Different grass types have unique mowing needs. Use this table as your go-to cheat sheet:
Grass Type Mowing Frequency Ideal Height
Kentucky Bluegrass Every 5–7 days
0.75 - 3.5 inches
Tall Fescue Every 7–10 days
1.5 - 4 inches
Perennial Ryegrass Every 5–7 days
0.75- 3.5 inches
Fine Fescue Every 10–14 days
1.5 - 4 inches
Bermudagrass Every 3–7 days
0.5-2.5 inches
Zoysiagrass Every 7–10 days
0.5 - 3 inches
St. Augustinegrass Every 5–7 days
1 - 3 inches
Bahiagrass Every 7–14 days
2.5 to 4 inches
Seasonal Impact on Lawn Mowing Frequency
  1. Season & Growth Rate
  • Grass grows faster in its peak season (spring for cool-season, summer for warm-season).
  • Example: Kentucky Bluegrass might need mowing every 5 days in spring but every 10 days in summer.
  1. Weather Conditions
  • Rain: Boosts growth, so you’ll mow more often.
  • Drought: Slows growth; mow less and keep grass taller to shield roots.
  1. Lawn Use:
    Busy areas may need more frequent cuts to stay tidy.
  2. Mower Blade Height
    Follow the one-third rule—never cut more than one-third of the grass height at a time.
  1. Fertilization & Irrigation
    Well-fertilized and irrigated lawns grow faster and need more mowing.
Grass Type Category Mowing Frequency Recommended Height
Kentucky Bluegrass Cool-Season Every 5-7 days
0.75 - 3.5 inches
Tall Fescue Cool-Season Every 7-10 days
1.5 - 4 inches
Perennial Ryegrass Cool-Season Every 5-7 days
0.75- 3.5 inches
Fine Fescue Cool-Season Every 10-14 days
1.5 - 4 inches
Bermudagrass Warm-Season Every 3-7 days
0.5-2.5 inches
Zoysiagrass Warm-Season Every 7-10 days
0.5 - 3 inches
St. Augustinegrass Warm-Season Every 7-14 days
1 - 3 inches
Centipedegrass Warm-Season Every 10-14 days
1 - 2.5 inches
Buffalograss Warm-Season Every 10-14 days
1.5- 4 inches
Pro Tip: according to different seasons/temperature/humidity (humidity/temperature sensor + electronic clock), identify different types of grass, intelligent adjustment; you can also adjust according to their preferences
Mowing Best Practices
Keep your lawn thriving with these tips:
  • Generally cut once a week (for traditional non-mowing robot lawn mowers)
  • Use Sharp Blades: Dull blades rip grass, causing damage.
  • Change lawn mowing patterns: Avoid compacting soil and promote even growth.
  • Avoid Wet Grass: Prevents clogs and uneven cuts.
Robot Lawn Mowers: A Hassle-Free Solution
Robot lawn mowers offer a convenient way to maintain your lawn with minimal effort. These devices can be scheduled to mow at specific times and intervals, ensuring consistent grass height and a well-maintained yard with zero manual work.
Want a Stress-Free Lawn Care Solution? Try Yarbo Robot Mowers
Yarbo’s robot lawn mower system makes sticking to the right mowing frequency effortless. With smart scheduling and automatic height adjustment, Yarbo ensures your lawn is always trimmed to the perfect length without you lifting a finger.
Why choose Yarbo?
  • Custom Scheduling: Mow exactly when and how often you need
  • Weather Awareness: Yarbo skips mowing during rain or extreme heat
  • Auto Height Adjustment: Perfect cuts based on grass type and growth
  • Clipping Management: Mulches clippings to nourish your lawn naturally
  • Quiet & Clean: Works silently and produces no emissions
Conclusion: How Often Should You Mow?
Understanding how often to cut grass starts with knowing your grass type and observing growth conditions. Stick to the one-third rule, mow at the right height, and follow seasonal patterns.
If manual mowing feels like a chore, Yarbo’s robot mowers provide a high-tech, no-hassle solution that keeps your lawn consistently healthy.
1. How do I know when it’s time to mow my lawn?
If grass blades are more than one-third taller than the recommended height, it's time to mow.
2. Does mowing frequency change by season?
Yes. Growth surges in spring and early summer mean more mowing. Dormancy in winter means less.
3. What happens if I cut my grass too short?
It stresses the lawn, invites weeds, and causes yellowing or bare spots.
5. Do different grass types really need different mowing schedules?
Absolutely. Bermudagrass needs frequent mowing; Fine Fescue can go longer between cuts.
6. Can robot lawn mowers keep up with fast-growing grass?
Yes. Yarbo robot mowers adjust mowing frequency automatically based on growth conditions.
