Do Robot Mowers Cut Edges? Discover the Truth with These 5 Insights
Apr 21, 2025 Buying Guides
Introduction to Robotic Lawn Mowers
Robotic lawn mowers have revolutionized lawn maintenance, offering automated solutions for homeowners seeking convenience and efficiency. These devices navigate lawns autonomously, trimming grass to a uniform height. However, a common question arises: can they effectively cut lawn edges?
Well, most robot mowers can and manufacturers claim that they can cut edges.
Understanding Edge Cutting in Robotic Mowers
What Is Edge Cutting?
Why Robot Mowers Struggle with Lawn Edges
Despite their advanced tech, most robot mowers still face challenges when it comes to achieving clean, crisp edges.
One key reason is the position of their blades, which are typically located under the center of the mower. This means they physically can't reach right up to walls, fences, flower beds, or narrow corners—leaving a small but noticeable strip of uncut grass along the borders.
RTK Technology Limitations:
Additionally, even the most modern robotic mowers that rely on RTK (Real-Time Kinematic) GPS technology for centimeter-level precision aren’t foolproof. RTK signals can become unreliable under dense tree cover, next to tall structures, or in areas with signal interference. When that happens, the mower may misjudge boundaries or avoid edges entirely to prevent crossing into unintended zones.
As a result, many homeowners still find themselves reaching for a manual trimmer or edger to clean up the leftover grass around the perimeter after the mower finishes its job.
Yarbo's Robot Trimmer:
While robotic mowers can handle 90–95% of the work, edge perfection often still needs a human touch—unless you're using a specialized model like the Yarbo Robotic Trimmer, which is designed to tackle this exact limitation.
The Yarbo Robotic Trimmer (2025 Edition) is a groundbreaking solution designed specifically to overcome the edge-cutting limitations of traditional robotic mowers. Part of Yarbo’s modular yard care system, this trimmer delivers unparalleled precision, versatility, and autonomy, making it the smartest and most advanced trimmer available in 2025. Here’s what sets it apart:
  • AI-Powered Precision: Equipped with high-resolution stereo vision cameras and advanced AI, the Yarbo Trimmer “sees” your yard, navigating around obstacles like trees, garden decor, and flower beds with near-human accuracy.
  • Floating Trimming Module: Unlike fixed-position blades, Yarbo’s unique floating module adjusts vertically and horizontally to tackle uneven terrain, ensuring flawless edges along fences, pavements, and contours.
  • Automatic Line Feeding: With a 95–99% success rate, the trimmer’s automatic line-feeding system eliminates the hassle of manual line replacements, ensuring uninterrupted operation.
  • Adjustable Cutting Heights: Customize your lawn’s appearance with cutting heights from 2 to 4 inches, perfect for tailored, professional results.
  • Modular Design: Seamlessly switch between trimming, mowing, blowing, or snow-clearing modes with Yarbo’s swappable attachments, offering a complete yard care solution.
  • Wire-Free RTK-GPS Navigation: Yarbo’s centimeter-level RTK-GPS ensures precise boundary mapping without boundary wires, overcoming signal interference for reliable edge trimming.
  • Eco-Friendly Operation: Powered by a 38.4 Ah battery with up to 210 minutes of runtime, the trimmer is emission-free and automatically returns to its docking station for recharging.
  • Smart Home Integration: Control and schedule trimming via the Yarbo mobile app, integrating seamlessly with your smart home ecosystem.
GPS and AI Integration
Limitations and Challenges
Robotic mowers may struggle with tight corners, narrow passages, or areas with dense vegetation. These physical constraints can hinder edge cutting effectiveness, requiring occasional manual intervention.
User Experiences and Reviews
Positive Feedback from Homeowners
Many users report satisfaction with robotic mowers' edge-cutting capabilities, particularly with advanced models. The convenience of automated lawn maintenance, including edge trimming, is a significant advantage.
Common Complaints and Issues
Some users express frustration over mowers missing edges, especially in complex lawn layouts. Discussions on forums highlight the need for improved edge-cutting performance in certain models.
Maintenance Tips for Optimal Edge Cutting
Regular Cleaning and Blade Replacement
Keeping blades sharp and free from debris ensures efficient cutting, including edges. Regular maintenance prolongs the mower's lifespan and maintains performance.
Software Updates and Calibration
Updating the mower's software can enhance navigation algorithms, improving edge-cutting accuracy. Periodic calibration ensures the mower operates within defined boundaries effectively.
Advancements in AI, sensor technology, and machine learning promise improved edge-cutting capabilities. Future models may offer enhanced adaptability to various lawn layouts and obstacles.
Q1: Do all robotic mowers cut lawn edges?
Not all robotic mowers are designed to cut edges precisely. Some models, especially budget options, may miss edges entirely or leave untrimmed strips along borders. Look for models with specific edge-cutting features like "Cut-to-Edge" or "EdgeCut" technology for better performance.
Q2: Which robot mower has the best edge-cutting capability?
The Mammotion Luba 2 AWD is currently one of the best for edge cutting, offering near-zero distance edge trimming with GPS precision. Husqvarna Automower models with EdgeCut and Worx Landroid models with offset blades are also excellent choices.
Q4: How close to the edge do robot mowers typically cut?
Q5: Do robot mowers work well around flower beds and garden borders?
Robotic lawn mowers are no longer just futuristic novelties—they’re practical tools for modern lawn care. While edge cutting was once a common drawback, innovations like GPS navigation, edge-dedicated blades, and AI-driven movement have significantly narrowed the gap between automation and perfection.
However, it's essential to match the mower’s capabilities to your lawn's layout and your aesthetic preferences. For those with complex landscapes or strict standards, choosing a robot with superior edge technology is worth the investment.
