Latest Yarbo Deal Just Dropped!
Do Robot Mowers Work on Tall Grass?
May 23, 2025 Usage Tips
Tall Grass
As robot lawn mowers continue to grow in popularity, many homeowners are asking the same question: Do robot mowers work on long grass?
Whether you're dealing with an overgrown yard after a long vacation or simply skipped mowing for a few weeks, it's crucial to know if your high-tech helper is up to the task.
In this article, we’ll dive deep into how robot mowers function, their limitations and strengths when it comes to long grass, expert recommendations, and the best tips for getting the most out of your robotic lawn care assistant.
Understanding How Robot Mowers Work
Robot mowers are automated devices designed to maintain your lawn by cutting grass consistently and gradually.
Key Features of Robot Lawn Mowers
  • Autonomous navigation: Uses sensors, GPS, or boundary wires
  • Cutting system: Often features multiple small blades or rotary blades
  • Battery powered: Recharge automatically via docking stations
  • Rain sensors: Many pause during wet conditions
  • Scheduling: Operate on customizable mowing schedules
Sensors and Navigation Systems
Modern mowers use:
  • Ultrasonic sensors for obstacle detection
  • Tilt and lift sensors for safety
  • AI algorithms for mapping and optimizing mowing patterns
These features make robot mowers excellent for maintenance — but what happens when grass grows tall?
Can Robot Mowers Cut Tall Grass Effectively?
Challenges Robot Mowers Face with Long Grass
  • Clogging: Tall, dense grass may clog the blades or wheels
  • Battery drain: Long grass creates resistance, and having the mower to go back and forth on the same spot over and over again reducing battery life
  • Missed spots: Navigation may be hindered by uneven terrain
  • Blade wear: High stress leads to faster blade dullness
Performance Comparison: Long vs Short Grass
Feature Long Grass Short Grass
Cutting Efficiency Moderate to Poor High
Battery Usage High Moderate to Low
Lawn Aesthetics Uneven, streaky Clean and uniform
Maintenance Requirement High Low
Bottom line: Robot mowers can work on long grass, but not without preparation and compromises.
Manufacturer Recommendations on Grass Height
Most manufacturers suggest mowing no more than ⅓ of grass height at once. Recommended starting height is:
  • 2-3 inches (5-7.5 cm) for most robot mowers
  • Anything taller should be reduced manually first
  • Check your user manual for model-specific guidance. For example:
Husqvarna Automower: Max height ~2.4 inches
Worx Landroid: Adjustable up to 3.5 inches
Ignoring these limits may cause malfunction, motor strain, or ineffective cutting.
Tips to Help Robot Mowers Handle Long Grass
  1. Gradual Cutting Strategy
Instead of expecting a clean cut in one go, run the mower multiple times over a few days, each at a lower height.
  1. Pre-Mowing with Traditional Tools
Use a manual mower or string trimmer to reduce grass height before starting your robot mower. This prevents motor overload and improves cutting results.
  1. Adjusting the Cutting Height
Raise the cutting deck to its highest level for the first run. Gradually lower it over subsequent sessions.
Features to Look For In Robot Lawn Mowers
  • High torque motors
  • Large cutting deck
  • Wide cutting height range
  • Rain sensors & self-cleaning
  • AI navigation for dense patches
Pros and Cons of Using Robot Mowers on Long Grass
Pros
Cons
  • Requires manual prep for overgrown lawns
  • Can damage the mower if grass is too tall
  • Not ideal for sudden, infrequent mowing needs
Maintenance Tips After Mowing Long Grass
  1. Blade Cleaning and Replacement
  • Clean blades after every session in long grass
  • Replace dull blades more frequently
  1. Battery and Motor Checkups
  • Ensure the motor isn’t overheating
  • Charge fully before long sessions
  • Look for signs of battery strain (e.g., short runtimes)
  1. Safety Precautions When Using Robot Mowers on Tall Lawns
  • Remove obstacles like sticks, toys, and rocks. Although the mowers can navigate through them, this would just delay the overall working time and result in an uneven cu.
  • Monitoring the mower during the first few sessions helps ensure that the mower is not facing any issues, problems or is getting stuck somewhere.
  • Ensure children and pets are not nearby during the operation
  • Never lift or tilt the mower when it's running as it can expose the blades while they are spinning, which can be dangerous for you or anyone nearby.
  1. Expert Insights: What Professionals Say
According to lawn care experts, robot mowers are not designed for heavy-duty trimming but excel with regular, low-height maintenance.
“Robot mowers are like a toothbrush — use it daily, and you’re good. Skip a few weeks, and you’ll need a deep clean first.” – Jake Monroe, Turf Specialist
Common Mistakes to Avoid
  • Letting grass grow too tall before first use, as every company has a instruction about the height of grass that the mowers can comfortably cut.
  • Forgetting to raise the cutting height can be a real problem as it tells the mower about the outcut you are expecting and the height of grass you need from it.
  • Expecting instant results in one session
  • Not cleaning blades after thick grass cutting, this can cloge the blade or even dull the blade if grass remains stuck to it.
Learn more about robot lawn mower maintenance.
  1. Can robot mowers cut very tall grass?
Not effectively. Most need the grass to be trimmed to 3.5 inches or lower.
  1. Will long grass damage my robot mower?
Yes, it can strain the motor, dull blades, and even clog the cutting system.
  1. Should I manually mow before using a robot mower?
Yes, especially if the grass is above the recommended cutting height.
  1. How often should I mow to avoid overgrowth?
At least 2–3 times a week during the growing season.
  1. What happens if my mower gets stuck in tall grass?
It will shut down or return to the base. Clear the path and resume.
  1. Are there robot mowers made specifically for tall grass?
Some models handle longer grass better due to higher torque, but none are built for extremely tall grass.
So, do robot mowers work on long grass? The answer is — yes, but with preparation. While they’re not made to tackle a jungle in your backyard, robot mowers can manage long grass if you use a step-by-step approach, choose the right model, and maintain your machine properly.
If you're serious about automating your lawn care, don’t let overgrowth become a roadblock. Mow smart, stay consistent, and let the robot handle the rest.
